Using existing symbols to make new ones
Is it me or is the library part of kicad still horendously primitive ?
I want to make a double bjt, do I seriously need to draw the whole thing from scratch ?
Why is it that when I give eschema a path to all of my custom libraries it’s like i did nothing?
Creating new libraries is a nightmare, it’s like something is missing in the functionality.
Anyone admits that this area could use some improvement and usability upgrades, but what is so hard about:
  • set an active library which contains something you want to start with
  • from load that symbol
  • make your changes/modifications/adjustments
  • set new active library
  • save symbol?
I’m 100% sure there are some double junction transistors in the transistor library… you might want to note the [Unit A] button at the top of the window (either editor or browser).
Maybe you’re after symbols with both units present, then this might be of help…DJT.lib (3.8 KB)
I’m talking about an NPN/PNP so I’d need to merge to symbols if anything, they need to appear together not as part A and part B, if I export a part into a single part library and then re import it into another library will it add one part to another or try to replace the existing artwork ?
See above library made by me.. there are all 3 variants (NPN/NPN, NPN/PNP and PNP/PNP) in there with both transistors in one symbol.
I just mentioned units A/B as some of the native KiCAD ones are DJT’s, but with separate symbols as I thought you might have missed that.
If the name for the new/imported part is the same as for a symbol in the library and save the library/part it will be overwritten, probably without warning (or I have switched that off).
For footprints the backup has saved my sanity/ass 2 times already.. didn’t had to test the backup for symbol libraries .. yet :wink:
well what i am actually looking for is the ability to copy and paste between symbols and libraries. Why draw from scratch a dual BJT when all i need to do is copy any NPN and any PNP into the same new part.
Also why are my custom libraries not being included when I set an additional folder path to find parts in ? it means i have to add every library manually, I use dropbox so that every computer I work on has all the data I need.
KiCAD isn’t able to do that … yet.
You can start with something that exists and draw the missing parts or if you feel brave take a text editor and copy&paste the parts you need from one symbol into the one where you want them.
I do stuff like that all the time..
Create a project template were you set up all those things once and work from that one..
