Hello!
I’m trying to use ERC, and I have a few issues.
ERC window disappears.
I have been misunderstanding it for a while, but I noticed that the window disappears
everytime I use it. Well, not everytime, but quite a lot.
Example:
Right now I have 9 errors and a few warnings.
When I choose ERC (clicking the icon on top), the current errors are displayed.
When I click “Run ERC” to update, the window disappears. Not everytime, but often. -
When the error window stays, clicking one error / warning make it disappear. Not everytime
either. For instance right now the first line (error) makes the window diappear. The second line
(warning) doesnt. I have thought it might be specific to warnings. It’s not. As I got a few occurrence
where it disappears on second click, but it seems unrelated. It disappears on first or second
click only. Whether it’s an error / warning doesn’t matter. Whether the error is in another page
also dosn’t matter.
Would it be possible to keep the window open until I close it? I mean : whatever happens,
error or not, warning or not, all errors solved or not, keep that window open.
Now, I have also issues unrelated to window closing.
Input power pin not driven by any output power pin.
I have read about this, and adding a power flag seems to solve the problem.
In my case, I have a switching regulator output connected to +5V. Isn’t it sufficient to make
all the 5V symbols potentially power sources? -
Warning: a pin with a no connection flag is connected.
The following chip is an RTC.
I have verified in the symbol that the pin MFP (multi function pin) is properly defined
and at least it’s not defined as “unconnected” (see belwow).
Beside this, there is no unconnected cross (x) in the schematic.
Can anybody explain me the meaning of this message?
Thanks,
By the way: my PC config is as follows:
Version: 7.0.2-6a45011f42~172~ubuntu22.10.1, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 2.7.4
FontConfig 2.13.1
libcurl/7.88.1 OpenSSL/3.0.8 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh/0.10.4/openssl/zlib nghttp2/1.52.0 librtmp/2.3
Platform: Ubuntu 23.04, 64 bit, Little endian, wxGTK, ubuntu, wayland
Date: Apr 17 2023 07:57:55
Boost: 1.74.0
OCC: 7.6.3
Curl: 7.85.0
ngspice: 38
Compiler: GCC 12.2.0 with C++ ABI 1017
KICAD_SPICE=ON
