Using both windows and macOS - Libraries problem
Use the environment variables to resolve relative path (Environment user-defined variables: how to use them?). It will require some manual editing of .pro and .sch files.
Or you can manually edit .pro and .sch to place the project-cache.lib on top of the library list. WARNING: this is somewhat unsafe procedure, but if you are aware its limitation it works quite nice.
