I tend to label a net when either (1) it has partcular significance or (2) simply to help me navigate when routing.
I am wondering whether there is a way to help avoid the mistake I did: I accidentaly created two names for the same entity - “B” and “Base”. A logical error on my part, and now circuitry on “B” does nothing useful on the final PCB.
A simple alphabetical list of user-named nets might be a helpful tool. A clickable list even better.
This is how I would use the feature: Simply scan it visually in case something feels wrong (like "well now, what does net B do … ?)
You can do this from pcbnew from the Inspect > List Nets… menu item. It’s not immediately obvious to me how to get the same in eeSchema. You may be able to generate a netlist in eeSchema and view the output file.
Many thanks for that tip Greg. That is already useful.
Still, it would be extra-useful to be able to click a column heading to sort by that column. Maybe this ‘sort’ feature could be a general feature of columnar lists?
It would be a nice touch to be able to do this directly from Eeschema also.
The InteractiveHtmlBom plugin really is a superb tool. I’ve been using it for assembly recently and it’s just great. I’ve also been doing some work to integrate it into Kitspace (might be deployed some time in the next week or two), and my biggest problem is that I get distracted by playing with it every time I should be testing my integration code! @qu1ck: do you have a Ko-fi or Patreon or something?
Just to confirm: you have the InteractiveHtmlBom plugin installed in your KiCad plugins directory, you choose “Tools” -> “External Plugins…” -> “Generate Interactive HTML BOM” from the menu in pcbnew, and a new browser tab pops up right away? You don’t see this dialog:
OK, that’s quite strange. I have a button in the tool bar too, and it pops up the dialog the same as the menu option (you’re right that they’re completely equivalent ways of running the plugin). One strange thing though: compare the icons (mine on the left, yours on the right):
Is that just a Linux/Windows difference, do you think? Or do we have different versions? If you run the plugin, go to your browser and mouse over the settings icon (the cog), you’ll see a menu that has the InteractiveHtmlBom version number at the bottom. Mine is v2.3. Is that what you have?
