Use StepUp to create footprint
stepup.zip (9.1 KB)
I’m trying to create a footprint using StepUp and FreeCad but I think this failed because the generated sketch has not connected edges. How can I make all the edges connected?
You can check the antena object inside the step file. I use it to create a projected sketch.
Thank you
Coincidence constrain on the endpoints that need to be “connected” (use box select to select the endpoints and then add the constraint)
I did what you say however it didn’t work as expected. Any other suggestion?
Thank you
antena.FCStd (4.1 KB)
complex pads need a circle somewhere that is used as the anchor pad.
Also pads_th_smd is the wrong name for generating complex pads. Check the antenna example for how to do it.
you can check also the complex-arc-pad example (Pads_Poly)
