Is it possible to create a module and place its drawings on the board outline layer? The layers that look as if they might work are the FAB Top and FAB Bottom (I think that is the name - one has the same colour and is the last in the list).
If I can do this, then I can have a set of outlines that are fixed and can be accurately defined - would be great.
Yes, I have used this method to create board outlines for PCBs which have a specific shape, and are not a simple rectangle. For example, PCB for Hammond 1553 box, Arduino. I also found using arcs in the board outline very buggy in pcbnew, so generating them externally allowed precise control.
Iām not sure what the FAB Top and Bottom layers are, those are new for me. The layer I used is āEdge.Cutsā. I also placed NPTH holes for mounting holes. There are some restrictions on the layers that can be used in a module. e.g. only text on front side.
I havenāt yet tried with Kicad v4, but the principle is hopefully the same.
draw the outline on F.Silk (should be default when you start drawing in the module editor).
then open the module in a text editor and change the layer from F.silk to Edge.Cuts.
donāt open + modify + safe this module in the footprint editor again or you have to repeat step 2, as the editor will move anything thatās on Edge.Cuts to F.Silk/etcā¦
IMHO Iād advise against it though as KiCAD doesnāt really like it.
I draw the outline for footprints on the Dwgs.User and for cutouts on Cmts.User in 0.05 thickness and redraw them in pcbnew.
Donāt find the arc drawing buggy, as I usually use just 90deg for this method and stay with 0.25 or 0.5 mm grid.
See this thread/post of me (explaining the edge.cuts in footprint editor)⦠also another example further down of how Iād do the outline for a RPi-Zero-Hat:
And yeah⦠Cmts.User color and Dwgs.User color deviate from the standard KiCAD setting⦠like it better that way and nicer to my eye
I created a testpcb module and edited the module file with a text editor. It worked and I could print the edges. But when I saved the PCB and opened it, it crashes.
It seems as if only a small change to KICAD to allow edges in the module editor, and then PCBNew to all them there.
I could possibly make a post processor to do the changes so that it makes the correct output file.
I could make a board outline using a standard module, and the edge on the front silk or a legal layer and simply use it as a template to check the layout and trace the edges over it.
I have seen ātemplatesā discussed, but it seems as if these are standard PCB designs and you then append them. But it would be nice to group the items.
It would be useful to have this as a standard feature of PCBNew
Thatās a philosophical thing afaik - the devs donāt want to be able to do this in the fp editor for footprintsā¦
Might even be defined as ābad practiceā in some standard for ECAD software somewhere⦠who knows.
At least one can change the layer for drawings to Cmts.User or Dwgs.User.
Which version was that?
Canāt remembering that happening in mine BZR6097ā¦
drawign a āfootrpintā with my board outline on F.silk
open in texteditor and replace F.silk with Edge.Cuts.
and all went fine.
the only thing that is sometimes a little annoying is that the footprint is āeverywhereā when you click inside the pcbā¦
for this a option for āfootprint only selectable on edge or lineā would be greatā¦
sunny greetings
stefan
Application: kicad
Version: 0.201512080931+6353~38~ubuntu15.10.1-stable release build
wxWidgets: Version 3.0.2 (debug,wchar_t,compiler with C++ ABI 1009,GCC 5.2.1,wx containers,compatible with 2.8)
Platform: Linux 4.2.0-19-generic x86_64, 64 bit, Little endian, wxGTK
Boost version: 1.58.0
I have gotit to go now with the latest KiCAD 4.0.1. and it did not crash.
It would be a simple change to allow KiCAD module editor to have drawings on the Edge.Cuts layer, with perhaps a warning if needed. I can write my own utility to do the changes from a known layer to edge cuts. but the fact that I can accurately define the the card layout is great, and of course I can now have predefined pads, labels etc all in one place.
Can you take out the restriction for the layer selection?
KiCad can import & save Edge.Cuts ok, in Kicad_Pcb files.
KiCad can also Save to Library, via footprint editor (do not edit any lines! (as above))
Why not ? Software should not limit the user control over the data. To me, that is a simple bug/defect.
Fills seem to work just fine with a Footprint based PCB outline.
Data imports and saves to library also ok.
It is only the Footprint Editor itself that is out of step here.
Maybe the issue they were avoiding by limiting the Editor, has since gone away ?
I find pick-footprint is by nearest ( I think it uses the bounding-box of PAD-Edges, plus outlines, if any) - you have to be well clear of a real footprint (outside that bounding box), to catch the board outline, so in practice this issue is there, but can be avoided.
You have to take that one up with the Devs on the mailing list⦠Iām just an enthusiastic forum moderator who uses KiCAD on a frequent basis
My personal opinion⦠it should be possible, yeah, but I can definitely life with it as-is and for sure would find other stuff more important and Dev-attention worthy than this.
