Hello ,
i want to design a schematic for 5v to 12v converter and i want to use as an input usb type c and as a an output a usb type B only for power delivery is and im not sure if this connections is enought to do the work
It’s best to ask in a dedicated electronics forum like EEVBlog. This forum is for using KiCad.
However looking at the schematic there are so many things wrong.
C? is not connected anywhere
C and R’s missing values and references
In fact most components are missing values/references.
There is a wire shorting the resistor connecting to base of 2N3904
There are far better and easier boost circuits for 5V to 12V like the MT3608
thanks yes for the reply the components missing values are still under finalisions about MT3608 i will take a look thanks a lot
If you use +5V power symbol then don’t go with wire through it.
At Usb_C_Plug you can have second +5V power symbol and even they are not connected by wire at schematic they are connected.
At USB3_B pin 1 see small square - that means wire connected to nothing.
Asking people to check a schematic, even drawn in KiCad, is an electronics design question and not a valid forum question.
