Upgrade Frustrations - libraries
My current version of KiCad is (5.1.9)-1
Hi, I’ve been using a 2012 version of KiCad and finally decided to upgrade to 5.1.9 because of access to all the new symbols and footprints available. Everything is going great until I try to create a new footprint. Since most symbols and footprints are variations of existing ones, I am used to:
  1. selecting an active library,
  2. loading a module (now footprint)
  3. editing
  4. selecting another active library, usually my custom collection
  5. saving the footprint into the active library.
First I looked in the manual - the menus don’t match and according to search results the manual is out of date.
I look in the forums. my first search results describe this same process, but then I notice that that was for older versions of KiCad.
I try the tutorials and focus on those for version 5.1. No joy!
Can someone please tell me how to do this specific 5-step process with the current version, or point me to the correct post?
Kind regards, Jurgen
Well it is a lot easier now (or at least more aligned to most other tools). Open the footprint you want to copy, file -> save as, select the library you want it to be saved in and done.
Or in the treeview right click on source footprint -> copy, right click on target library -> paste.
And to make a new library just use file -> new library. Then select if you want this new library to be part of the global library table or the local one.
Further reading:
The reason that it does not work for you is very likely because the default libraries are read-only. This is done on purpose, because changes you make to them can be overwritten when KiCad is updated.
So you have to do a few extra steps.
  • Create an empty library.
  • Copy a standard symbol to that library.
… and that is pretty much what Rene added to his FAQ article.
Hi Rene,
I appreciate the quick reply. Seems to work. Once I edit the footprint and save it under a new name, I need to remember to delete the copied one.
Thanks, Paul. I already had a personal library set up. I was hung up on loading the footprint from one library into the editor to edit and then saving it to the new library.
Cheers.
