I’m experiencing a problem probably related to functionality change in one of the later versions of Pcbnew.
When I right click on a footprint in Pcbnew and select “Update Footprint…” then “Update all footprints on board” and press Apply, I’m used to all footprints being updated from the footprint library. This is still the case, but the texts in the footprints are not being updated. If I’ve changed the size, location, visibility or such on any of the texts in the footprint this is not being updated on the board.
I can see that this can be a good thing, since texts which has manually been moved to a “better” position is now not reset to default position. However, in my case I where I have updated 20-30 different footprints I would really like to reset all footprints on the board according to the library.
Is there any way I can completely update all footprints? Maybe by backing down to an older version, or using a nightly build or a python script (I don’t have any experience with Python)?
I’m using KiCad 5.0.0 release build under Windows 10.
Thanks in advance!
Kind regards,
Albin
