Hi
What exactly can be directly updated from the schematic with this new tool / feature ?
It works for components values, but not for references (which require a netlist update) and probably not for net names. It seems it is not documented yet.
Hi
It will do everything, that the old way of generating a netlist and importing it into pcbnew did before. It is pushing the netlist information directly without generating the file.
You don’t ever need to generate a netlist anymore. Renaming nets definitely works and what do you mean by references? If you change the reference number on a part, on the pcbnew side you can decide if you want to import changes by reference number or timestamp just like before.
Thanks for your reply.
I didn’t notice the reference / timestamp option.
Indeed, reference modification now works if the update is done by matching the timestamp. Excellent !
