I see there are ways to update the schematic from changed footprints on the PCB, but it there a way to do the reverse? I’ve tweaked some footprints, saved them in my library, and then called them up in the schematic. I now want to update the PCB with the new footprints.
Thanks - I tried that but it is not updating the footprints (2 of them with small dimensional changes) - I checked and it does update circuit changes to the PCB, but I’m not getting the footprints through.
Update PCB from the schematic [F8] is a good idea when you have modified the schematic (such as changing footprint links), but if those footprints (same name, but an “older” copy) are already on the PCB, they probably do not get updated. To complete the task, also do a: PCB Editor / Tools / Update Footprints from Library.
