Hello all,
I back again with another question for all the really smart people out there lol, but anyways on my project I’m working on I recently got my prototype boards in and started working on soldering on my components to the board and quickly realized that I needed to tweak my design a little from what I had. One of those changes was that I needed to upscale my power connector to my board from a S2B-PH-K-S(LF)(SN) to a DF1BZ-2P-2.5DS power connector because the s2b’s pin socket on the female plug was just to small for me to crimp with my crimp tool and I wasn’t getting a solid connection. So I up scaled to a slightly larger connector (DF1BZ) to have a little bit bigger of a cable plug and a better chance of crimping my custom wire harness together.
Well in doing so I had to update my schematic layout to accompany the new plug types in my diagram. When doing so I now am getting the following error codes:
Conflict problem between pins. Severity: warning
pin 2 (passive) of component r1 is connected to pin 1 (Unspecified) of component j1 (net 3)
pin 1 (unspecified) of component j1 is connected to pin 2 (unspecified) of component j2 (net 3)
Conflict problem between pins. severity: warning
pin 1 (passive) of component d2 is connected to pin 2 (unspecified) of component j1 (net 4)
pin 2 (unspecified) of component j1 is connected to pin 1 (unspecified) of component j2 (net 4)
Not really to sure whats going on but before with the old power connections I had no errors at all but now that I have upgraded to a slightly bigger connector I have these 4 errors now and was just wondering how I can fix this problem. Any and all help would greatly be appreciated.
Thanks for the time and the help.
