Unit independent placement of reference
When I place in a multi unit symbol the reference designator in one unit like this:
it appears on all other units on the same position like this:
“All units interchangeable” is off:
grafik
Is there a way to independently place the reference across the units?
Marko
No.
already open gitlab issue: Allow Symbol fields to have different positions in different units (#6512) · Issues · KiCad / KiCad Source Code / kicad · GitLab
workaround mentioned in first answer in that topic.
Thanks for the answer, even that it means that it can’t be done.
I will not use the workaround, since hopefully the issue will be solved one day and I don’t want to mess up my libs.
Marko
