Unique identifier in hierarchical schematic?
I am quite new to kicad and dealing with a multichannel schematic where i use hirarchical sheets with the replicate layout plugin. So far all working fine, all channels working. Now i have a large connector in the root that has dedicated inputs that i need to wire to each channel / hirarchical schematic, how can i do this ? if i use global or hirarchical label they are copied and not unique in each hirarchical schematic. how can i do this ?
Use hierarchical labels.
Inside of the subsheet the hierarchical labels are like lokal labels.
After wiring you can check the connectivity with the “highlight wire” tool/hotkey.
Then you will see if some nets are connected or not connected.
The highlighting remains even if you switch from rootsheet–> first subsheet → another subsheet.
i did but the hirarchical label is copied to the other as well … so it is not unique per subsheet
oh dear … the name stays same but i can connect it to different pins … great … thanks ! i split GND in half as i use 2 power supplies
You may also look into buses for projects like these. The thing you gain, is that you get to use less wires. And you may benefit from prefixes.
Regards,
Bas
