I installed KiCad 7.99 from source on Ubuntu 22.10. I would like to completely remove the source built version and install an older version via the apt package. I followed the guide on the KiCad site to build it from source. Could anyone point me in the right direction on how to get the source built version completely removed so I can start fresh? Thank you
Maybe make uninstall?
Make install should show what it does line by line. You can look at that and delete things manually.
Apologies, I should have tried that first.
sudo make uninstall
worked just fine. Thank you
