Hi everyone, I am new to this forum so apologies if this is posted to the wrong place or in the wrong way.
I have a random ratsnest line that can’t understand the cause of. One of the endpoints of the ratline is the Mvdd net (highlighted), and the other endpoint seems to go to nothing in the editor, but in the 3D rendering there is a copper “dot” (zero length trace?) rendered.
Would be grateful if someone could shed light on this. TIA
@Naib - bottom layer is solid GND all around there (I put it in wireframe view for the screenshot).
I went through all the nets listed in “Inspect->List Nets”, and there is nothing shown on either of the 2 copper layers at the right endpoint of the line …
Version 5.1.0 is old, you should update to 5.1.9. It’s very possible that not showing zero length segments in the layout is a bug which has been fixed.
You can try to hunt it down with a text editor. Try to locate the exact coordinates of the ratsnest line end and search for it in the text editor.
@eelik – This worked! I searched for the endpoint coordinate in the text file and found it instantly. Deleted line, problem solved. If anyone cares, it is below. In any case I’m all set. Many thanks!!
