I am new to KiCad and I was doing a fun project. I finished the project and generated the gerber files and the drill files. Then I tried to load it in the GerberView in KiCad. For some reason I am getting some errors.
After closing the error window, the board loads up. I am wondering if I made a mistake and will it affect the manufacturing project?
That’s a small bug; KiCad let’s you select a drill file along the gerbers from the same Open dialog view but gives this error. As long as you see what you need in the actual view, everything is OK.
