ekoeck
November 19, 2019, 10:00am
1
Hey there, has anybody an idea what this warning message means? I have one track where this warning pops up every time I press U or I to select (part of) it. I already deleted the track and routed it newly but the warning persists, but beneath the warning message there doesn’t seem to be another issue. At least I can continue to work normally, just curious what I’m doing wrong.
TIA!
Screenshot_2019-11-19_10-41-49|466x339
Application: KiCad
Version: 5.1.4-e60b266~84~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 4.15.0-70-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.4.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
eelik
November 19, 2019, 11:19am
2
I got this same message recently. Has something been changed in 5.1 branch bug fixes which made this appear?
Application: Pcbnew
Version: (5.1.5-rc1-5-g37f23fa53)-1, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Can you provide a minimal board that shows this?
eelik
November 19, 2019, 1:22pm
4
It may be difficult to repeat. I closed and reopened the board and the problem in that place went away. So, sending a board may not help at all. The editing sequence which leads to that should be found, but it’s not easy.
ekoeck
November 19, 2019, 2:01pm
5
The warning somehow disappeared (maybe through reopening as well). If someone could describe what this message means it would be easier to provoke it an provide a minimum working example.
Seth_h
November 19, 2019, 2:15pm
6
If you are experiencing this issue, please add details to https://bugs.launchpad.net/kicad/+bug/1838261
Ideally, we would like to know exactly how you triggered it, modes you were running, screencap, etc.
Russ
November 19, 2019, 2:17pm
7
eelik, You are using a different version of kicad, and a different operating system.
ekoeck
November 19, 2019, 2:49pm
8
@Seth_h thanks for the link. I reported my part and will see if I can contribute further.
system
Closed
February 17, 2020, 2:49pm
9
