After successful routing without any remaining error I selected the whole PCB, then right-clic and Special Tools / Create Array a 2x3 panel. Works properly except that a new RatNest is created interconnecting the 6 individual PCBs.
What am I doing wrong?
Best,
Christian
Version info Please note: don’t request me to upgrade Kicad because 6.0.11 is the lastest available for my MacPro 5,1 2010 and OS X 10.4.6. Thanks to programmed obsolescence . Upgrading toward an earlier MacPro would cost waaaay too much!
Nothing. It’s a normal consequence of 6 copies of the nets being in the array. The PCB editor thinks they should be connected. If you are sure each board is correct you could ignore the ratsnest.
To eliminate the ratsnest the paneliser would have to give each of the nets unique IDs, like GND001, GND002, and so forth for every net. Just ignore the lines, generate the gerbers and forget them. I assume you have planned some way of separating the array, like V-cuts?
Yes, sent the PCB to JLC and assumed 0.4 mm V-cut as advised. Also added edge rails, holes and fiducials (but useless as mounting will be by hand soldering). JLC replied PCB is OK.
