Understanding SDRAM configurations
Hi Forums,
I am working on a project that would require me to have a 4GB SDRAM. I dont know to understand the configuration for this.
for example I have chosen the part https://www.digikey.co.uk/product-detail/en/micron-technology-inc/MT41K256M16TW-107-XIT-P/557-1757-ND/6036287 would this mean that i have to have 4 of these chips in parell for me to have 4GB of memory ? is there a easy way to understand this?
Sorry about the very basic question this is the first time I am designing a DDR based design.
-Pix
I can’t tell if you are talking bits or bytes.
Those chips are 4Gbit, so 4 give you 16Gbit. That is a total of 2Mbyte.
Hi BOBC,
Thanks, Understood I am looking for gigabit. so for being not so clear.
-pix
In that case you should be looking for four chips each 1GB with 64Mx16 layout.
Can I not have like a single chip for the entire 4GB ? it will avoid me some of the pitfalls of pcb routing, I am cautious as I would have to follow strict routing rules.
-Pix
You can if you can find a chip with the required bus width, which you haven’t specified but by implication is 64 bits. I don’t know what memory controller you are using, since you haven’t told us.
I don’t make RAM chips, you should consult your supplier to see what is available :slight_smile: Routing DDR has challenging rules, so you are going to have to tackle that anyway.
I would strongly advise finding someone who can supervise you, and also study some reference designs.
Sorry I forgot to mention the info. I am planning to base the design on the beaglebone, instead of the am335x i am planning on upgrading it to am437x and make a dslr camera dolly with image capture using usb and image processing using ffmpeg.
I am planning on using emif which supports
– DDR3 and DDR3L: 400-MHz Clock (DDR800 Data Rate)
– 32-Bit Data Bus
– 2GB of Total Addressable Space
– Supports One x32, Two x16, or Four x8
Memory Device Configurations
Thanks I will try to find someone to help me with my supervision. I am using the am437xgpevm and beaglebone green schematic as a reference.
-Pix
The specs you quoted indicate a maximum of 2GB address space, so providing 4GB of RAM doesn’t sound like a good idea.
They also indicate that you can use a single x32 DRAM part, so a 512Mx32 part would provide 2GB in a single chip, if you can find one.
thanks very much @kpfleming
