Pcbnew (and Eeschema) both have Preferences
-> "Save/Load Project File..."
options.
Can someone explain why/when it is necessary to save/load a project file from within Eeschema or Pcbnew?
One reason why I’m asking is because I came across these options when I was trying to make a project template (http://docs.kicad.org/stable/en/kicad.html#_creating_templates), and discovered that preferences in the .pro
file do not update until I explicitly click the Save Project File...
For example, when I change the solder mask web preference value in Pcbnew and hit the save button, the .kicad_pcb
file immediately stores the correct value (solder_mask_min_width 0.1016)
. However, the .pro
file still shows SolderMaskMinWidth=0.000000000000
until I click the Save Project File...
, which causes the value to update to SolderMaskMinWidth=0.1016
Why are these settings (seemingly) stored in two places and updated through different mechanisms? When are the settings in the .pro
file used vs. the ones in the .kicad_pcb
file?
