Hi folks:
I am trying to understand which features of a power port component qualify it for which power port behaviors. Which might be in docs somewhere, but if so, I haven’t found it, so please point to it if it’s there.
The behaviors in question are:
- implied attachment to a power net
- being offered by the “Place power port” tool
- possibly other behaviors I don’t know about?
I see that a power port and its pin has the following attributes that might be involved:
Power port component:
[ ] Show pin number
[ ] Show pin name
[ ] Define as power symbol
The Component Name:
[string] Text
[ ] Invisible
The Field Reference:
[ ] Invisible
The single pin:
[string] Pin name
[choose] Electrical type: “Power input” seems to be what the provided power port pins use, but “Power output” is an available choice [Point 3 below]
[ ] Visible (“Schematic Properties”)
My guess is as follows:
It’s the pin’s Electrical type = “Power input” that invokes automatic attachment to the net named by the pin’s name. Not affecting this behavior (my guess): The Component Name [note A], the component’s “Define as power symbol”, and the pin’s Visible property [note B].
Component “Define as power symbol” determines whether the component gets offered by the “Place power port” tool. (And no other effect.)
Am I right about these? Also:
- Why do power port power supply pins have attribute Electrical type set to “Power input”? On the face of it, that type makes sense for a component that uses the power, but not for one that supplies the power. It seems that this aberration is what drives the needs for the PWR_FLAG component to provide a source for a net like VCC which connects to other components’ power input pins.
Other notes:
Note A: In the supplied power port components, it looks like the Component Name is set to match the pin name. I guess that’s because the pin is usually hidden to avoid visual clutter. However, as I guessed above, it’s the pin name that matters, and not the component name? It would be possible to create a component named “-5V”, with a pin “100V”, not Visible, and it would connect to the 100V net, right?
Note B: The schematic editor has a preference “Show hidden pins”, which appears to override the pin “Visible” setting unchecked. The fact that power pins can be hidden, thus affording surprise connections to some net, perhaps explains the many forum posts about issues with “hidden power pins”. I guess, but don’t know, that the hidden aspect does not actually influence whether or not the pin connects to a net, right?
(As a side note to developers, it’s unnecessarily vague and misleading to use different terms for the same thing in different parts of the UI. here Visible vs Hidden, and “Define as power symbol” vs inclusion on list of symbols offered by a tool. (Assuming I guessed these right.))
