Hi
I have an issue in routing, While run the DRC for PCB it shows an 3 unrouted but while trying to connects those unrouted pads, there is nothing. Error msg by kicad has enclosed. Can any one to help this ??
Can you share your board file?
Last one sounds like there is a pad number on something non copper, which there shouldn’t be
Or at least a screenshot of the affected area
Hi
I have found that issue. I have pour the copper in bottom layer of GND but it is not connected the GND pad to some of the components. So i have routed those pads to GND pins.
