It seems that kicad is now moving from launchpad to git(github), and the doc repository is not available at its location.
Eventually maintainer of kicad-install will need to adjust the repositories or better - use the new git-based ones.
To solve the issue for now:
edit the kicad-install.sh file and change this line:
Thank you for your help.
In order to be able to update Kicad, in addition to your suggested modification I had to rename to .old Kicad-doc.bzr as it seems that the command bzr up looks iside that directory to retrieve the address of the repository and does not rely on the DOCS_REPO variable.
Now I am updated to build 6225.
In case the kicad team will migrate the entire project to git, I hope they will supply a new version of the script, as, examinig the script, I guess that once known the right repositories to use and the necessary git commands, it should not be difficult to modify the script.
I ran in the exact same problem. I followed your solution @kubatyszko and it worked fine. But now I got an error and I can’t find a solution.
[100%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface.dir/__/common/base_units.cpp.o
Linking CXX shared module _pcbnew.kiface
/usr/bin/ld: ../../boost_root/lib/libboost_system.a(error_code.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
../../boost_root/lib/libboost_system.a: error adding symbols: Bad value
collect2: error: ld returned 1 exit status
pcbnew/CMakeFiles/pcbnew_kiface.dir/build.make:6106: recipe for target 'pcbnew/_pcbnew.kiface' failed
make[2]: *** [pcbnew/_pcbnew.kiface] Error 1
CMakeFiles/Makefile2:1313: recipe for target 'pcbnew/CMakeFiles/pcbnew_kiface.dir/all' failed
make[1]: *** [pcbnew/CMakeFiles/pcbnew_kiface.dir/all] Error 2
Makefile:137: recipe for target 'all' failed
make: *** [all] Error 2
I also try to complile it from the source. But i get the exact same error. Perhaps you guys have any ideas about this?
