Check with your manufacturer if they likes your way of making a slot. Placing drills that close can lead to drill breakage. (drill tries to wander into the already drilled hole -> drill bends -> drill breaks)
Good point. They specify this method so I think they manually convert to a milling operation when they see it. I will also add a note somewhere for them.
