Unable to connect traces with two vias
I have a +5V line I need to run from the top to the bottom of my PCB. I originally connected them with a via, with no issue. I later decided to add a second via to improve current handling. I can’t get it to work! I place the second via next to the first, on the bottom trace. Then, I extend the upper trace over the via. Then, the bottom trace connecting the second via disappears. If I replace it, the top trace disappears. Seems like a lovely feature instead of a bug, but I have no clue. How do I use two (Or more) vias to connect traces?
Is this ticked ?
That was it. Thanks!
