I’m trying to build todays kicad nightly from source on ubuntu 24.04.1 and the way I used to do it was following this tutorial Linux | Developer Documentation | KiCad
but now (after trying to remove kicad and everything related to it completely) I get some error trying to build it saying ngspice is none existing and before removing previous kicad build I had errors related to protobuf lib here’s the recent one:
-- Checking for module 'ngspice'
-- Found ngspice, version 43
*** NGSPICE library missing ***
Most of ngspice packages do not provide the required libngspice library.
You can either compile ngspice configured with --with-ngshared parameter
or run a script that does the job for you:
cd ./tools/build
chmod +x get_libngspice_so.sh
./get_libngspice_so.sh
sudo ./get_libngspice_so.sh install
CMake Error at /usr/share/cmake-3.28/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find ngspice (missing: NGSPICE_INCLUDE_DIR)
Call Stack (most recent call first):
/usr/share/cmake-3.28/Modules/FindPackageHandleStandardArgs.cmake:600 (_FPHSA_FAILURE_MESSAGE)
cmake/Findngspice.cmake:162 (find_package_handle_standard_args)
CMakeLists.txt:862 (find_package)
-- Configuring incomplete, errors occurred!
ninja: error: loading 'build.ninja': No such file or directory
I’d like to completely nuke and remove kicad from my ubuntu and aptitudes repo and start all over to allow installation but I’m not sure how to do that perfectly if anyone has an idea on how to do it?
Here is how I tryed building from source so far(am getting some errors installing the prebuilt apt version of nightly as well):
sudo add-apt-repository -s --yes ppa:kicad/kicad-dev-nightly
sudo apt update
sudo apt build-dep kicad-nightly
sudo git clone https://gitlab.com/kicad/code/kicad.git /usr/local/my_kicad_nightly && \
cd /usr/local/my_kicad_nightly
sudo mkdir -p build/release
cd build/release
sudo cmake -G Ninja -DCMAKE_BUILD_TYPE=RelWithDebInfo ../../
sudo ninja
sudo ninja install
This is the error being displayed when I try to install the stable prebuilt version of kicad with
sudo add-apt-repository ppa:kicad/kicad-8.0-releases
sudo apt update
sudo apt install kicad
The following packages have unmet dependencies:
libocct-visualization-7.6 : Depends: occt-misc (= 1:7.6.3+dfsg1-9~ubuntu24.04.1) but 1:7.8.1+dfsg1-3~ubuntu24.04.1 is to be installed
E: Unable to correct problems, you have held broken packages.
Solved this with this:
Search the Web. Privately. Truly useful results, AI-powered answers, & more. All from an independent index. No profiling, no bias, no Big Tech.
sudo apt-get remove occt-misc
sudo apt-get purge occt-misc
sudo apt-get update
sudo apt-get install occt-misc=1:7.6.3+dfsg1-9~ubuntu24.04.1
sudo apt-get install libocct-visualization-7.6
So back to stage 1 I got past the ngspice problem apperantly the ngspice install script got removed so borrowed from here: get_libngspice_so.sh · GitHub
but now the protobuf package is missing:
CMake Error at CMakeLists.txt:883 (find_package):
Could not find a package configuration file provided by "Protobuf" with any
of the following names:
ProtobufConfig.cmake
protobuf-config.cmake
Add the installation prefix of "Protobuf" to CMAKE_PREFIX_PATH or set
"Protobuf_DIR" to a directory containing one of the above files. If
"Protobuf" provides a separate development package or SDK, be sure it has
been installed.
If you are on Ubuntu 24 or older try -DKICAD_USE_CMAKE_FINDPROTOBUF=ON in your cmake command
I might have screwed it up a bit I’ve also installed
sudo git clone https://github.com/protocolbuffers/protobuf.git
sudo mkdir build
cd build
sudo cmake ../ -DCMAKE_BUILD_TYPE=Release -Dprotobuf_BUILD_SHARED_LIBS=ON -Dprotobuf_BUILD_TESTS=OFF
sudo make -j4 install
and then tryed to build kicad with:
sudo cmake -G Ninja -DCMAKE_BUILD_TYPE=RelWithDebInfo -DKICAD_USE_CMAKE_FINDPROTOBUF=ON ../../
sudo ninja
sudo ninja install
then saw you comment tryed the same and gave me the same error trying to build kicad so i also tryred to remove the protobuf source build manually from
‘/usr/local/lib/cmake/protobuf’
and
‘/usr/include/protobuf’
tryed you option with:
sudo ninja
sudo ninja install
but this gives me the following error:
/usr/local/my_kicad_nightly/include/api/api_handler.h:96:57: error: conversion from ‘google::protobuf::internal::GetTypeNameReturnType’ {aka ‘std::basic_string_view<char>’} to non-scalar type ‘std::string’ {aka ‘std::__cxx11::basic_string<char>’} requested
[47/1507] Building CXX object gerbview/CMa...e_objects.dir/tools/gerbview_control.cpp.o
ninja: build stopped: subcommand failed.
$FZF_DEFAULT_OPTS: unknown option: --walker=file,dir,follow,hidden
$FZF_DEFAULT_OPTS: unknown option: n
Should I also uninstalled the source built ngspice?
full error message from sudo ninja
FAILED: common/CMakeFiles/common.dir/api/api_handler_editor.cpp.o
/usr/bin/c++ -DBOOST_ATOMIC_DYN_LINK -DBOOST_ATOMIC_NO_LIB -DBOOST_CHRONO_DYN_LINK -DBOOST_CHRONO_NO_LIB -DBOOST_LOCALE_DYN_LINK -DBOOST_LOCALE_NO_LIB -DBOOST_THREAD_DYN_LINK -DBOOST_THREAD_NO_LIB -DGLM_FORCE_CTOR_INIT -DHAVE_STDINT_H -DJSON_HAS_FILESYSTEM=0 -DKIAPI_IMPORTEXPORT=APIIMPORT -DKICAD_BUILD_ARCH_X64 -DKICAD_CONFIG_DIR=kicad -DKICAD_IPC_API -DKICAD_SCRIPTING_WXPYTHON -DKICAD_SIGNAL_INTEGRITY -DKICAD_UPDATE_CHECK -DNANODBC_ENABLE_UNICODE -DUSINGZ -DWXUSINGDLL -D_FILE_OFFSET_BITS=64 -D__WXGTK__ -I/usr/local/my_kicad_nightly/include -I/usr/local/my_kicad_nightly/common/. -I/usr/local/my_kicad_nightly/common/./dialogs -I/usr/local/my_kicad_nightly/common/./widgets -I/usr/local/my_kicad_nightly/common/./dialog_about -I/usr/local/my_kicad_nightly/resources/bitmaps_png -I/usr/local/my_kicad_nightly/3d-viewer -I/usr/local/my_kicad_nightly/pcbnew -I/usr/local/my_kicad_nightly/kicad -I/usr/local/my_kicad_nightly/build/release -I/usr/local/my_kicad_nightly/scripting -I/usr/local/share/ngspice/include -I/usr/local/my_kicad_nightly/thirdparty/argparse/include -I/usr/local/my_kicad_nightly/build/release/api/cpp -I/usr/local/my_kicad_nightly/build/release/api/cpp/api -I/usr/local/my_kicad_nightly/thirdparty/pegtl -I/usr/local/my_kicad_nightly/thirdparty/magic_enum/magic_enum -I/usr/local/my_kicad_nightly/thirdparty/libcontext -I/usr/local/my_kicad_nightly/libs/kimath/include -I/usr/local/my_kicad_nightly/libs/core/include -I/usr/local/my_kicad_nightly/thirdparty/clipper2/Clipper2Lib/include -I/usr/local/my_kicad_nightly/thirdparty/other_math -I/usr/local/my_kicad_nightly/thirdparty/rtree -I/usr/local/my_kicad_nightly/libs/kiplatform/include -I/usr/local/my_kicad_nightly/thirdparty/dynamic_bitset -I/usr/local/my_kicad_nightly/thirdparty/expected/include -I/usr/local/my_kicad_nightly/thirdparty/picosha2 -I/usr/local/my_kicad_nightly/thirdparty/json_schema_validator -I/usr/local/my_kicad_nightly/thirdparty/nlohmann_json -I/usr/local/my_kicad_nightly/thirdparty/thread-pool -I/usr/local/my_kicad_nightly/build/release/common -I/usr/local/my_kicad_nightly/thirdparty/fmt/include -I/usr/local/my_kicad_nightly/libs/kinng/include -I/usr/local/my_kicad_nightly/build/release/include/gal/shaders -I/usr/local/my_kicad_nightly/thirdparty/nanosvg -I/usr/local/my_kicad_nightly/thirdparty/dxflib_qcad -I/usr/local/my_kicad_nightly/thirdparty/tinyspline_lib -I/usr/local/my_kicad_nightly/thirdparty/compoundfilereader -isystem /usr/local/my_kicad_nightly/thirdparty/pybind11/include -isystem /usr/include/cairo -isystem /usr/include/pixman-1 -isystem /usr/include/freetype2 -isystem /usr/include/harfbuzz -isystem /usr/include/opencascade -isystem /usr/lib/x86_64-linux-gnu/wx/include/gtk3-unicode-3.2 -isystem /usr/include/wx-3.2 -isystem /usr/include/python3.12 -isystem /usr/local/my_kicad_nightly/thirdparty/nanodbc -Wno-attributes -pthread -Wall -Wsuggest-override -Wduplicated-branches -Wduplicated-cond -Werror=vla -Wimplicit-fallthrough=5 -Werror=return-type -Wshadow -Wsign-compare -Wmissing-field-initializers -Wempty-body -Wreorder -Wmismatched-tags -Wpessimizing-move -Wredundant-move -Wno-psabi -O2 -g -DNDEBUG -std=c++20 -fPIC -fvisibility=hidden -fvisibility-inlines-hidden -ftrivial-auto-var-init=zero -MD -MT common/CMakeFiles/common.dir/api/api_handler_editor.cpp.o -MF common/CMakeFiles/common.dir/api/api_handler_editor.cpp.o.d -o common/CMakeFiles/common.dir/api/api_handler_editor.cpp.o -c /usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp
In file included from /usr/local/my_kicad_nightly/include/api/api_handler_editor.h:24,
from /usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:21:
/usr/local/my_kicad_nightly/include/api/api_handler.h: In instantiation of ‘void API_HANDLER::registerHandler(HANDLER_RESULT<ResponseType> (HandlerType::*)(const HANDLER_CONTEXT<RequestType>&)) [with RequestType = kiapi::common::commands::BeginCommit; ResponseType = kiapi::common::commands::BeginCommitResponse; HandlerType = API_HANDLER_EDITOR; HANDLER_RESULT<ResponseType> = tl::expected<kiapi::common::commands::BeginCommitResponse, kiapi::common::ApiResponseStatus>]’:
/usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:34:54: required from here
96 | std::string typeName = RequestType().GetTypeName();
/usr/local/my_kicad_nightly/include/api/api_handler.h: In instantiation of ‘void API_HANDLER::registerHandler(HANDLER_RESULT<ResponseType> (HandlerType::*)(const HANDLER_CONTEXT<RequestType>&)) [with RequestType = kiapi::common::commands::EndCommit; ResponseType = kiapi::common::commands::EndCommitResponse; HandlerType = API_HANDLER_EDITOR; HANDLER_RESULT<ResponseType> = tl::expected<kiapi::common::commands::EndCommitResponse, kiapi::common::ApiResponseStatus>]’:
/usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:35:50: required from here
/usr/local/my_kicad_nightly/include/api/api_handler.h: In instantiation of ‘void API_HANDLER::registerHandler(HANDLER_RESULT<ResponseType> (HandlerType::*)(const HANDLER_CONTEXT<RequestType>&)) [with RequestType = kiapi::common::commands::CreateItems; ResponseType = kiapi::common::commands::CreateItemsResponse; HandlerType = API_HANDLER_EDITOR; HANDLER_RESULT<ResponseType> = tl::expected<kiapi::common::commands::CreateItemsResponse, kiapi::common::ApiResponseStatus>]’:
/usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:36:54: required from here
/usr/local/my_kicad_nightly/include/api/api_handler.h: In instantiation of ‘void API_HANDLER::registerHandler(HANDLER_RESULT<ResponseType> (HandlerType::*)(const HANDLER_CONTEXT<RequestType>&)) [with RequestType = kiapi::common::commands::UpdateItems; ResponseType = kiapi::common::commands::UpdateItemsResponse; HandlerType = API_HANDLER_EDITOR; HANDLER_RESULT<ResponseType> = tl::expected<kiapi::common::commands::UpdateItemsResponse, kiapi::common::ApiResponseStatus>]’:
/usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:37:54: required from here
/usr/local/my_kicad_nightly/include/api/api_handler.h: In instantiation of ‘void API_HANDLER::registerHandler(HANDLER_RESULT<ResponseType> (HandlerType::*)(const HANDLER_CONTEXT<RequestType>&)) [with RequestType = kiapi::common::commands::DeleteItems; ResponseType = kiapi::common::commands::DeleteItemsResponse; HandlerType = API_HANDLER_EDITOR; HANDLER_RESULT<ResponseType> = tl::expected<kiapi::common::commands::DeleteItemsResponse, kiapi::common::ApiResponseStatus>]’:
/usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:38:54: required from here
/usr/local/my_kicad_nightly/include/api/api_handler.h: In instantiation of ‘void API_HANDLER::registerHandler(HANDLER_RESULT<ResponseType> (HandlerType::*)(const HANDLER_CONTEXT<RequestType>&)) [with RequestType = kiapi::common::commands::HitTest; ResponseType = kiapi::common::commands::HitTestResponse; HandlerType = API_HANDLER_EDITOR; HANDLER_RESULT<ResponseType> = tl::expected<kiapi::common::commands::HitTestResponse, kiapi::common::ApiResponseStatus>]’:
/usr/local/my_kicad_nightly/common/api/api_handler_editor.cpp:39:46: required from here
[725/2231] Building CXX object common/gal/CMakeFiles/gal.dir/opengl/opengl_gal.cpp.o
Uninstall your source-built protobuf and use the Ubuntu packages. Use the CMake define I gave above. Blow up your CMakeCache.txt to make sure you aren’t dealing with any stale configuration.
uninstalled the ‘/google/protobuf/’ directories and re downloaded kicad dependancies and repo with:
sudo apt update
cd build/release
but sudo cmake -G Ninja -DCMAKE_BUILD_TYPE=RelWithDebInfo -DKICAD_USE_CMAKE_FINDPROTOBUF=ON ../../
Gives me the same previous error:
Could NOT find Protobuf (missing: Protobuf_INCLUDE_DIR)
/usr/share/cmake-3.28/Modules/FindProtobuf.cmake:749 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
CMakeLists.txt:881 (find_package)
Strangly I have tryed installing protobuf through apt with:
sudo apt-get install protobuf-compiler libprotobuf-dev
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
protobuf-compiler is already the newest version (3.21.12-8.2build1).
libprotobuf-dev is already the newest version (3.21.12-8.2build1).
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
but I can’t see is has recreated the folder ‘/usr/local/include/google/protobuf/’ I removed manually
(I search for “protobuf” using fzf and can’t see it anywhere from ‘/’ directory where does apt usually install it? am I missing something?)
system
Closed
April 25, 2025, 4:43pm
11
