Hi there
I am adding my custom footprint library.
footprint editor --》preferences 》footprint library wizard 》files on my computer then folder selection then to global lib config or current project only then click finish.
But in library search window there is no custom lib…
Thanks
Instead of footprint wizard, select the library manager option… then take a screenshot of the bottom of that list there:
It’s a good idea for any directories and files that you might want to update eg via GitHub, to be in /users/yourname/kicad.
Program Files requires administrator rights to write
Which one doesn’t work… test.pretty or test1.pretty?
Also, how does your KISYSMOD path variable look like (it’s in that same window, in the area below)?
PS: for screenshots I’d use something else than a camera
https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
The Windows “Snipping Tool” is great for screenshots and very easy to use!
Dale
Or lookup Greenshot for a nice shot grabber
Thanks
For what exactly? Could you solve your problem?
