Ubuntu PPA nightly builds don't build
It seems the nightlies from the Ubuntu ppa do not build anymore since ca. 3 weeks.
This one was the last I have seen which built correctly:
https://launchpadlibrarian.net/792691097/buildlog_ubuntu-noble-amd64.kicad_202505111451+5e6ef67fce~182~ubuntu24.04.1_BUILDING.txt.gz
This is the last one which does not build:
https://launchpad.net/~kicad/+archive/ubuntu/kicad-dev-nightly/+build/30897918/+files/buildlog_ubuntu-noble-amd64.kicad_202506011454+2124f2b846~182~ubuntu24.04.1_BUILDING.txt.gz
I tried to compare the outputs but I could not find the root of the problem.
Is this a known issue? Should this be reported somewhere?
In the meantime someone also created an issue in gitlab.
Seems someone has fixed it.
Since yesterday they build successfully again.
The only thing you can rely on with the nightly is its unreliability; after all, it is in continual development. :wink:
