Ubuntu 5.1.6 install issues
Hi All, newbie here trying to get KiCad 5.1.6 going on Ubuntu 18.04.5. When I run:
sudo add-apt-repository --yes ppa:kicad/kicad-5.1-releases
I get the error:
E: Repository ‘http://ppa.launchpad.net/kicad/kicad-5.1-releases/ubuntu bionic InRelease’ changed its ‘Label’ value from ‘WIP: Don’t use yet !! PPA for KiCad: 5.1 releases’ to ‘PPA for KiCad: 5.1 releases’
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Can anybody help?
Thx,
Jeff
If you run it without the --yes, does it prompt you to accept the label change?
(if so, just accept it)
Good idea. I’ll try it…
same message unfortunately…
Sounds like you are cached already. Try:
sudo apt-get --allow-releaseinfo-change update
If Seth_h’s method doesn’t work (more than likely he is correct) possibly when you removed --yes ended up with wrong number of spaces. Found link for PPA for KiCad: 5.1 releases where you can check this. Never know just another idea. I’ve chased similar issues when copy and pasting ending up with difference created by editor I was using on a different installation. Seth helped me on my installation questions on 20.04.
https://launchpad.net/~kicad/+archive/ubuntu/kicad-5.1-releases
thx all. I’ll give it a try…
Perfect! Thx so much. That fixed it…
