bonjour
j’ai realiser un typon sur une face (f.cu)
je voudrais le dupliqué sur la l’autre face (b.cu)
comment faire
merci
Hello
I made a artwork on one side (f.cu)
I would like the duplicate on the other side (b.cu)
how to do
thank you
bonjour
comment faire
merci
Hello
how to do
thank you
Select all the items you want to duplicate
Right button -> duplicate
Edit the duplicated selection by pressing “e”
Then, change the layer to B.Cu
Unfortunately that doesn’t work because KiCad can’t open Properties dialog of graphic items if there are more than one items in the selection. However, you can Flip the selected items, which may be better suited for your needs anyways because graphics will look right when you flip the board.
There exists a small simple plugin script with which it’s possible to change the layer of the selected items, https://github.com/easyw/kicad-action-tools.
done
You are wrong, @eelik. As far as all of those items are tracks, the properties dialog can be opened.
Edit: I certainly misunderstood the OP and thought the artwork was implemented with tracks, misguided by the F.Cu layer.
Yes, tracks and vias are a special case. I just supposed it was graphic items because it was “artwork”.
I’m waiting for the “property inspector” or “object inspector” for v6 with which it should be possible to edit (arbitrary) properties of different kinds of items. That would solve several different problems at once without need for specialized dialogs or script plugins for different items.
