Two Pours on Same Layer [Solved]
I have a power plane on my four layer stackup and I would like two pours, one for 5V and the other for 3V3.
I’ve created the two zones but only one of them will generate a pour. I am sure I am doing something stupid/simple to stop this from working, but what?
Thanks!
Plane is filled if can be connected to at least one pad or via with the same net.
You can define one of them for the whole board (if you wish). Setting priority you decide which one is filled first and then second one takes the area left.
Perfect, thanks Piotr. Just like you said, I only had to create a track with a single via on the 5V side and the pour now works. Cheers!
