In the past, I had to work with this kind of phototransistor, where the 2 pad are on the same coordinate but on different layer. We had to redial the hole halfway to remove the plating.
But sadly I’ve never been able to create a footprint without DRC error, I’m also interested with that kind of design, to connect a coaxial cable for example.
If a footprint guru is out there some tips would be greatly appreciated
I don’t know if this will work without printing the gerbers out but I just stacked two smd pads on top of a NPTH and it let me. Doesn’t display correctly in the 3D viewer but gerbers would tell the real story I guess.
I get an unconnected pad error. I don’t see any thing else. But, I haven’t integrated it into the design. I just dropped it onto an existing schematic to see if it worked as a footprint.
@hermit you are right… it this case the bottom pad should have a pad number, because is connected to a component terminal, but if designed as NPTH kicad cannot assign a pad number to a mechanical pad…
(the two top pads have the same pad number)
