Sometimes I would like to see footprint, catalogue number fields etc. on the schematic, but a company requirement is to hide such details on some versions of the schematic to reduce clutter.
Is there a simple way to do this?
‘Edit->Update fields from library’ presumably requires the visibility to be changed in the library, so this is no good…?
I had high hopes for ‘Tools->Edit Symbol Fields’ but that doesn’t seem to change the visibility of the fields even if I deselect them and then ‘Apply, save schematic and continue’. Is this a bug or the expected behaviour?
There used to be a menu item or shorcut key to make all invisible symbol fields visible on the schematic. It was however years ago since I last saw that option, and am not sure if it still exists in KiCad.
The setting in KiCad also was a “all or nothing” setting, which cluttered the schematic to such an extreme point that it’s usability was questionable.
For example, all the long datasheet links and long footprint links.
qu1ck noted python scripting.
Currently Eeschema has no integrated scripting capability, but you can of course use scripts directly on the schematic files, like the C example above.
You can probably use existing libraries to read the schematic into Python, or you can simply start from the description of the KiCad File format, load the schematic as text and manipulate it that way.
If you have a bit of knowledge of Python, such a thing should be doable in a day of work or less.
