Turn off footprint display
Is there an easy way to globally turn off display of the footprint in the schematic. I know I can click on a component and hit E to edit and uncheck the ‘show’ for the footprint, which works. But doing it for every component is going to be tedious :frowning:
Cheers.
Phill.
This is by design. The goal is to teach you patience for your life.
Sadly there was a backdoor introduced so you can circumvent this long tedious learning process: Edit–>Edit Text and graphics properties
To affect the footprint field select “other symbol field” in the scope section.
Excelent that was exactly what I needed, thanks.
Cheers.
Phill.
