Is there a way to turn off the ERC Rule “Pins of type Output and Output are connected”? I can’t seem to find it. I know how to solve the error, I just want to know if it’s possible to turn of that check. If it’s not possible, that’s a bug right?
That’s a “pin conflict” ERC warning. Go to the Pin Conflicts Map page and change the settings for that entry (output vs output) from error to ignore.
Note: you may know this already, but in KiCad it is convention to create your symbol differently in order to avoid this kind of ERC warning. I’m not sure what your part is or what the STB pin does, but typically I would not set a GND pin as an output.
This way an OUTPUT could be tied to GND. However, that STP pin might need to be an INPUT type as generally tying an OUTPUT to GND is asking for damage (hence the ECR)
