I can´t get this to work in 9.0.1 I am using.
Got information from ChatGPT how to do it and some Youtube videos but nothing happens when I try.
Made a simple test with to caps and a single track between them.
Also assigned a net name.
Is this a bug in 9.0.1 or what is wrong?
I’m not quite clear on what you are trying to do.
To get started with kicad I suggest you to check official kicad documentation instead IA appliances or videos.
I want to just test this function to get the desired length of a single track. I am developing a Power Amplifier with 10 parallell transistors and want it to have the same length to all of them for better performance.
I managed to get this function to work once now but I cannot reproduce it again.
I start in eeschema and put in 2 resistors this time and select a footprint for both resistors.
Drag a connection between them.
Update PCB and place them on PCB apart from each other.
Press X to drag a wire between them.
Press 7 and try to tune the length of the wire but I can´t select the connection between the resistors.
Yes, exactly what I want to do.
This is the card I am building, from the XLR input and OPA1633 differential amplifier I shall feed 10 buffers on the positive side and 10 on the negative side (mirrored the upper half of the card, not done yet) to get a full balanced amplifier. The lengt of the wire to them should be the same.
Works for me on 9.0.2. PS. are you designing an audiophile amplifier?
Yes, but not for commercial use. A hobby of mine.
Where can I get 9.0.2, I have seen Nightly builds and 9.0.1.250 build?
I worked for me too in my v9.0.1 test build
Make sure the review the setting after you select the tool, right click and the “Length tuning settings …”
Version: 9.0.1-152-g2cebea3b04, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: ATI Technologies Inc., AMD Radeon (TM) Graphics, 4.6.0 Compatibility Profile Context 24.9.1.240813
Date: Apr 14 2025 05:44:55
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
EDIT:
