Once a differential pair length has been tuned is there any way to remove the meanders apart from deleting the meandering track and then adding a new differential track.
The reason for doing this is as a result of changing a connector the tracks are too long. My guess is that length tuning only increases the length it will not reduce a length that already contains meanders.
From memory you cannot retune and have it shortern a meander pattern,
You can however delete a meander segment back to a straight trace and check how close you are, Ive resorted to manual fine tuning the ends a few times where the pattern isnt quite bang on.
