Trying to use kikit 1.6.0 on 8.0.7 throws error
Trying to use kikit to panelize a PCB - but when running it, I get an information message:
ufunc ‘create_collection’ not supported for the input types, and the inputs could not be safely coerced to any supported types according to the casting rule “Safe”
Any idea what causes it ?
Kikit panelize command used:
kikit panelize^
    --layout "hspace: 3mm; vspace: 3mm; vbackbone: 3mm; rows: 2; vbonecut: False; baketext: False" ^
    --tabs "type: fixed; vwidth: 5mm; vcount: 3; hcount: 0" ^
    --cuts "type: vcuts" ^
    --framing "type: frame; hspace: 3mm; vspace: 3mm; maxtotalheight: 100mm; maxtotalwidth: 100mm" ^
    --tooling "type: 4hole; hoffset: 2.5mm; voffset: 2.5mm; size: 1.152mm" ^
    --fiducials "type: 4fid; hoffset: 5mm; voffset: 2.5mm; coppersize: 1.52mm" ^
    --text4 "type: simple" ^
    --post "millradius: 1mm; refillzones: True" ^
    "H:\Electronics\espirgbani_pio-master-20241222\pcb\rgb.kicad_pcb" "<missingOutput>"
If you have a problem with a plug-in, you are likely to get a more helpful response from the plug-in author - so check the KiKit website first.
For others that arrive here.
