Trying to setup KiCad Build Environment on Win11: vcpkg install failed
I am trying to setup a build environment for KiCad according to the official build documentation on a new Win11 pro computer. Basically a clean install. There is no (other) version of python installed on the machine. Locale is German.
Kicad Source is cloned from git to ``O:\src`.
Vcpkg resides in O:\src\vcpkg by cloning from github (as in description).
O:\src\CMakeSettings.json has path to vcpkg:
            "environment": "vcpkg",
            "VcPkgDir": "O:/src/vcpkg/"
CMake is giving me these two errors upon configuring the build environment:
CMake Error at scripts/cmake/vcpkg_execute_required_process.cmake:127 (message):
1> [CMake]     Command failed: O:/src/vcpkg/downloads/tools/python/python-3.12.7-x64-1/python.exe O:/src/vcpkg/buildtrees/wxpython/src/8854625dd8-861bd167bd.clean/public/get-pip.py --no-warn-script-location
1> [CMake]     Working Directory: O:/src/vcpkg/buildtrees/wxpython
1> [CMake]     Error code: 1
1> [CMake]     See logs for more information:
1> [CMake]       O:\src\vcpkg\buildtrees\wxpython\get-pip-x64-windows-err.log
1> [CMake]
1> [CMake] Call Stack (most recent call first):
1> [CMake]   O:/src/build/x64-Debug/vcpkg_installed/x64-windows/share/vcpkg-get-python-packages/x_vcpkg_get_python_packages.cmake:48 (vcpkg_execute_required_process)
1> [CMake]   C:/Users/Me/AppData/Local/vcpkg/registries/git-trees/feabd68376664732bb0ae763c33daaf3a2427ac5/portfile.cmake:35 (x_vcpkg_get_python_packages)
1> [CMake]   scripts/ports.cmake:196 (include)
1> [CMake] error: building wxpython:x64-windows failed with: BUILD_FAILED
1> [CMake] See https://learn.microsoft.com/vcpkg/troubleshoot/build-failures?WT.mc_id=vcpkg_inproduct_cli for more information.
1> [CMake] Elapsed time to handle wxpython:x64-windows: 1.3 min
1> [CMake] Please ensure you're using the latest port files with `git pull` and `vcpkg update`.
1> [CMake] Then check for known issues at:
1> [CMake]   https://github.com/microsoft/vcpkg/issues?q=is%3Aissue+is%3Aopen+in%3Atitle+wxpython
1> [CMake] You can submit a new issue at:
1> [CMake]   https://github.com/microsoft/vcpkg/issues/new?title=[wxpython]+Build+error+on+x64-windows&body=Copy%20issue%20body%20from%20O%3A%2Fsrc%2Fbuild%2Fx64-Debug%2Fvcpkg_installed%2Fvcpkg%2Fissue_body.md
1> [CMake]
1> [CMake] -- Running vcpkg install - failed
1> [CMake] CMake Error at vcpkg/scripts/buildsystems/vcpkg.cmake:904 (message):
1> [CMake]   vcpkg install failed.  See logs for more information:
1> [CMake]   O:\src\build\x64-Debug\vcpkg-manifest-install.log
1> [CMake]   C:/Program Files/Microsoft Visual Studio/2022/Community/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.29/Modules/CMakeDetermineSystem.cmake:146 (include)
1> [CMake]   CMakeLists.txt:47 (project)
1> [CMake] -- Configuring incomplete, errors occurred!
Vcpkg was checked out from github, so it should be the latest version. This doesn’t give me any clues:
O:\src\vcpkg>git pull
Already up to date.
O:\src\vcpkg>vcpkg update
the update command does not currently support manifest mode. Instead, modify your vcpkg.json and run install.
note: updating vcpkg by rerunning bootstrap-vcpkg may resolve this failure.
Have also tried to run bootstrap-vcpkg again. But that doesn’t help either.
The two log files mentioned above look like this:
O:\src\vcpkg\buildtrees\wxpython\get-pip-x64-windows-err.log :
Traceback (most recent call last):
  File "O:\src\vcpkg\buildtrees\wxpython\src\8854625dd8-861bd167bd.clean\public\get-pip.py", line 33324, in <module>
    main()
  File "O:\src\vcpkg\buildtrees\wxpython\src\8854625dd8-861bd167bd.clean\public\get-pip.py", line 135, in main
    bootstrap(tmpdir=tmpdir)
  File "O:\src\vcpkg\buildtrees\wxpython\src\8854625dd8-861bd167bd.clean\public\get-pip.py", line 111, in bootstrap
    monkeypatch_for_cert(tmpdir)
  File "O:\src\vcpkg\buildtrees\wxpython\src\8854625dd8-861bd167bd.clean\public\get-pip.py", line 92, in monkeypatch_for_cert
    from pip._internal.commands.install import InstallCommand
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\commands\__init__.py", line 9, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\cli\base_command.py", line 15, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\cli\cmdoptions.py", line 23, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\cli\parser.py", line 12, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\configuration.py", line 26, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\utils\logging.py", line 27, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\utils\misc.py", line 39, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\locations\__init__.py", line 14, in <module>
  File "C:\Users\Me\AppData\Local\Temp\tmpneu4gmkd\pip.zip\pip\_internal\locations\_distutils.py", line 9, in <module>
ModuleNotFoundError: No module named 'distutils'
The file O:\src\build\x64-Debug\vcpkg-manifest-install.log contains the following error:
    Error code: 1
Anybody experience the same issue?
O yea, you can’t use the latest vcpkg currently because of the shitshow known as python support.
Checkout a version of vcpkg from August.
I have pushed a ducktape solution to avoid the conflict with a newer vcpkg root. Eventually this will be less of a problem when we drop python support.
As far as I can tell git checkout 2024.09.30 of the vcpkg repository will get you the newest working version. I am successfully compiling with that version.
I think I misunderstood @marekr . It looks like the latest update to the
kicad-vcpkg-registry
implements a workaround. So, now we can use the newest version of vcpkg again?
Is there an alternative replacement planned?
Dear @marekr,
I have removed the vcpkg- Folder and started off again with a git clone --tag 2024.08.23 ...
CMake finished successfully with configuration this morning. :slightly_smiling_face: :upside_down_face:
Have to continue with modifying my launch.vs.json later tonight…
Thanks a lot for your advice ! :+1: :+1:
Yes
@LangerJan how are you going with your windows dev environment?
I’ve only managed to get it build in WSL with basically ubuntu.
Building with on windows with visual studio definitely works. Where does your built fail?
Thanks for checking.
I’am quite new to hacking on KiCad. I tried to se up my laptop for the Learn to Code KiCad day prior to FOSDEM.
The guys from the core dev team got it running on my machine fast. So compiling works, but KiCad is not an easy project to start off with.
Since I don’t have the full notion of vcpkg I have not dared to touch it again. So I cannot comment, if the windows build is currently working.
From what I learned on the coding day is that most of the developers are happily using native Linux as build environment. Mark is the mastermind taming the windows build system. He is very supportive. You might want to ping him and adress your problem to him directy.
so far its been the vcpkg builds for some packages and then the cmake configuration is failing. I’ll get some more screen shots tonight.
this is what I am getting at the moment. ngspice fails to build
build-x86-windows-rel-out.log (63.6 KB)
Version:
MSVC\14.43.34808
You are attempting a 32-bit windows build. 32-bit is not supported.
