Now that the BOM table already exists
Maybe the XY position of the component can be added.
Make a SMT file.
And the Y position parameter must be a positive number.
Now kicad does not understand why the Y position is a negative number, is it to circumvent a patent?
Local SMT factories do not support position files with negative numbersHUB_4USB2514B_POS.csv (3.9 KB)
Sorry, I don’t follow. Are you saying the placement file that KiCad generates is invalid because it has negative Y coordinates? The file you attached doesn’t have any negative coordinates.
But either way what does this have to do with the plugin?
Oh, I’ve modified the position file and matched the local SMT factory.
The original file Y-axis exported by kicad is a negative number
That info would have been useful in the first post. But again, I don’t see what this has to do with the plugin. I suggest you report this on bug tracker.
The origin for the .pos file is the auxialiary origin in pcbnew. The negative-Y or the negative-X coordinates depend on the auxiliary origin position, that can be placed anywhere, even outside the pcb.
So select the bottom-left corner of your pcb as the position of the auxiliary origin if you want every coordinate to be positive.
Just a reminder: Yes kicad uses a left handed coordinate system (positive y axis points downwards)
But this is mapped correctly on export to the pos file that uses a right handed system.
Mentioning this here as it could easily be one of the sources of confusion.
