Trouble with PcbNew footprint
Yesterday, I decided to layout the common signals for my UARTS, the timer and the PPI chips. This entailed the data base, reset, some address lines, the I/O read/write and the data bus. While I was routing the I/O ~RD line the trace would not connect to the correct the PPI 8255 pin. After zooming in I saw that the 8255 was labeled I/O ~WR instead. So I figured I made the symbol wrong. Yet the schematic has it correct Pin t is I/O RD and pin 36 is I/O WR. So I went back into my custom library and checked it out a completely as I could. Checked each pin and ran the Check for Duplicate and Off grid pins, that was OK. I then remade the Net List and checked the IO.NET file. Here Pin 5 is I/O~RD and Pin 36 is I/O~WR which is correct. I also checked to see if the 8255 was listed twice, figuring that maybe a later one had it wrong, but no soap. Then in PcbNew I deleted my old 8255 from the layout, then updated the PCB only to find that pins 5 and 36 are swapped again. In the dialog box shown when the update is done says that Pin 5 is connected to I/O ~WR and Pin 36 is connected to I/O ~RD, which is wrong. I struggled with this most of the yesterday and have not had any luck repairing this. Does anyone have an idea of how to fix this? Thanks Mike.
post your files :white_large_square:
OK, I’m still new at this what files would you like to see? Mike
at a minimum, your .lib and .kicad_mod. best just zip your whole project directory.
I hope this is what you are looking for. Please remember I’m a novice at this and it maybe a little messy. Thanks Mike
IO.zip (348.1 KB)
Looks like you’ve got these net labels swapped.
Thank you. Sometimes I can look right at something and not see it. My wife tells me that when I’m looking in the refrigerator most every day. Getting old I spect. Mike
Sometimes I see what I expect to see instead of what is there. :frowning:
I think you are correct in saying that. Many times I have in my mind exactly what something looks like, but it’s not the same anymore. I can remember things from 60 years ago, better than something I did yesterday. Well… I swapped the NETS and it work perfectly. Thanks a million. Mike
