Trouble sending a bus to another sheet
I’ve been trying to follow the examples posted here dating from 2015 to 2019 on running a bus from the main sheet to a subordinate sheet and have come upon a roadblock. When I asked about it in kicad@libera.net, I was told this may be a bug, not me now knowing what I’m doing. Here, I’ve broken the problem down to the simplest possible example.
That ERC complaint, I was told should not be there. What’s really going on?
Here’s the test project: https://www.dropbox.com/s/bvvp0jot8jlro87/sheet-bug.zip?dl=0
The problem is the label in the root-sheet.
Inside of the subsheet-rectangle you have to place a hierarchical sheet pin (not a simple label / bus label).
So delete the D[0…7] inside the rectangle. Than use the “import a hierarchical sheet pin”-button on the right side toolbar and now with this activated tool click inside the subsheet-rectangle.
Thanks. This wasn’t quite clear to me on how to get lines or busses from sheet to sheet.
