Hello!
Who knows about 3d models of transformers and el. substations including equations and theory?
Also it is enough to use usual Kirhgof laws and others to create a tr-r?
Hello!
Here’s a 3D model:
https://grabcad.com/library/three-phase-oil-immersed-hermetically-sealed-distribution-transformer-tmg-400-1
And here’s the theory:
Kirchhoff and phasors are more than enough. Note that symbols with primes are referred to the primary side
Thanks! And if we create substations - which consist tr-r and switches,and others?
Pretty sure ABB has step models of medium voltage switchgear publicly available. Probably others, too.
BTW: I would strongly advise against building substations based on Internet forum knowledge.
What is ABB? )) Thanks
ABB is a manufacturer who makes transformers that do not fit on a PCB such as:
https://duckduckgo.com/?q=abb+transformer&t=h_&iax=images&ia=images
ABB’s Idea of a substation is possibly also slightly different from what you have in mind:
https://duckduckgo.com/?q=abb+substation&t=h_&iar=images&iax=images&ia=images
Let me know if you render it with KiCad 3D-Viewer
I’ll let you know if the viewer can’t handle it.
Thanks. Suppose we have a method, that can calculate parameters and equations of el. circuit. In arbitrary type of equations, and interval - what can we add here so the system can solve problems of radio circuits - and be like a candy? &)
Hi!
Who can help with substations formulas - examples of simple with transformers?
Any papers in pdf. Scientific engineering
