I have created a schematic in a project using Kicad version 5.1.8, that I would like to use as a starting point in a revised and expanded project. How do I transfer the original schematic into the new revised project?
I would simply start with:
- Create new project.
- Exit KiCad.
- Copy existing schematic file to new project.
- Give the new copy the name of the project.
- Open KiCad / Eeschema.
- Check if it works.
- Fix errors.
Update:
I just tried this and it seems to work. If your old schematic uses custom libraries, you have to fix those manually.
