Or may be because the end point specify by the user mouse, so it need to be on the grid, and that make it impossible for auto-route reach the destination without violating DRC at the destination?
Hi Tom,
Even if you are a developer, and one of the most important ones, I tell you to try my solution.
I’m sure the manual routing relies on the grid. With the exception of the magnetic pads.
You can test it easily: select a 5mm grid and try to route a track.
Cheers,
Pedro.
I also have experiences when I have changed grid to smaller and managed to route a track which was otherwise unroutable.
I agree with eelik, routing seems to depend on grid spacing. Things I cannot route at 25 mil grid do route at 1 mil grid.
Thanks @twl … I’m using v5.0.0.
OK, try 5.0.2 or the latest nightly, I don’t see this extra clearance issue there.
Tom
As Tomasz mentioned, you might try 5.0.2. You are running into a bug where tracks identified as differential pairs would have their single track clearance to all nets computed using the differential pair gap. This was fixed for 5.0.1 and later.
