Track width for inner layers
Hi guys
may i know how to mention the track width for internal layers i just can’t find it in Pcbnew
Regards
Nick
Hi there is currently no way of defining DRC rules which differ per layer.
See previous post: (Yes it only has one answer.) Different DRC for different layers
As mentioned in this post, you can make a feature request over at launchpad.
(There may already exist one.)
thanks rene
then how to deal with routing in internal layers having track width of 0.1mm on external layer and 0.2mm on internal layer there should be a way to modify track width on the fly manually is ok
Regards
Make sure that 0.1mm and 0.2mm are configured as Custom Track Width:
http://docs.kicad.org/en/pcbnew.html#_specific_sizes
Then switch on the fly from the toolbar or with the W and Ctrl-W shortcuts.
http://docs.kicad.org/en/pcbnew.html#_select_edit_the_track_width_and_via_size
http://docs.kicad.org/en/pcbnew.html#_setting_track_widths_and_via_sizes
