Track width editor problems
So far have not been able to edit track default width, & set up a width table?
managed to change with individual single tracks, but when trying to enter in Width table, no entry possible!
How do you set up a pull down width table?
Is there some credible step by step procedure out there?
In V7 it is in: File-Board Setup-Design Rules-Pre-defined Sizes.
But as you are not new to forum than I can suppose that may be you know it and your question is about V8 (it is not clear from your question). If so then I didn’t run V8 yet so know nothing.
Also learn to use net classes. If you have net classes set up properly, then KiCad can automatically use the defined widths in the net classes when routing different nets. Also, just read the manual for these two features. (You may also read the rest of the manual too of course).
Figured it out, not quite as intuitive as earlier versions.
Up to recently I have been working with an older ver on a PC with WIN XP but now have switched over to my other online WIN10 PC & Kicad 7
