Track Corner Mode - Hotkey Question
If you hit CTRL+/ when routing you can toggle between right angle, 45 degree angle and arc based routing. While I have a special place in my heart for arc based routing, I rarely if ever use it. While I use the 45 degree routing about 99% of the time. When breaking out a pad with long straight side, I find that going to right angle routing is the correct move.
My question is, can I set a hot key that goes straight to my routing method of choice without having to toggle through three choices of which one choice is almost never the choice? If there isn’t then I’ll submit a feature request.
Jason G.
Sorry, no.
