I have designed a PCB in kicad v7. When I created the gerber files and opened them in gerber view of kicad there are no traces showing on the board. I checked from the gerber viewer of JLC PCB but the same problem. I dont know if this view is correct or not. I have opened the gerber files of other pcb designs that I have created but those are all correct and have traces showing up there. But in this design I am getting this problem. I dont know if its even a problem or not.Please someone can guide me
It does not look right. I can see some pieces which look a bit like thermal spokes, but the angles are wrong.
The most likely cause is an error during gerber file creation. I guess you have turned on a copper layer with Plot on all Layers. Normally all the layers in this list are off for creating gerber files.
